certain tempertures that i cant install weather stripping?
Old Dec 6, 2011 | 09:07 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
is there any certain temperature that i cant install weatherstripping? reason i ask if im about to order new roof rail and door seals and want to know if i can go ahead and install or if i need to wait till spring.
Old Dec 6, 2011 | 10:28 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: certain tempertures that i cant install weather stripping?
The instructions on the adhesive would tell you. Generally, above 50°F is ideal.
Similar to flooring, let all the materials acclimate to the same temperature.
Old Jan 2, 2012 | 02:36 PM
Engine: L31 350
QUestion what would happen if I used my adhesive below 50? I really want to get these installed but it's not 50 here so what would happen if I used it below?
Old Jan 2, 2012 | 05:17 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
I'm about to install weather stripping myself. I'm in NH, so its pretty cold here and wont be 50 degrees for months. The adhesive package doesnt mention anything about temperature so im assuming it should be ok. I also asked someone who installs widnshields and they said it should be fine.
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
It wouldnt dry correctly. If you have a garage or a friend w/ one, so there and do it... Set up a heater and get it up to temp... after about an hour or 2 (according to the outside temp) you should be good to go putting it on...
Old Jan 2, 2012 | 05:20 PM
Engine: L31 350
Iv got my garage and I had two heaters going in there but it was still cold, what do you mean it wouldn't dry right?
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
g.l.mos
Aug 22, 2015 12:02 AM
