Worn out exterior
Old Dec 7, 2011 | 07:53 AM
ZROCz28's Avatar
Worn out exterior
So as im building my new motor i want to help out the exterior of my car, the paint is chipping and fading with no clear coat left, i have a nice dinger right above my pass. wheel well in the front ans my frint ground fx have cracks and splits. I just need some suggesetions on easy fixes right now just to get her to look a bit better
Old Dec 8, 2011 | 10:35 PM
skully-bones 13's Avatar
Car: 1985 Camaro IROC-Z
Engine: 305 w/ 4 barrel carb
Transmission: brand new 700r4
Re: Worn out exterior
i have the same problem haha, so im kinda curious as well
Old Dec 9, 2011 | 12:40 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Depends on what you're willing to spend, and what kind of results you're looking for. On the cheap side, here's a thread involving a high-polished $100 DIY paintjob that looks pretty good in pictures:
https://www.thirdgen.org/forums/body...paint-job.html
There's always budget body/paint shops like Maaco that will paint a car for $249, but don't expect it to look good unless it's from a distance...
Old Dec 10, 2011 | 12:43 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
No real shortcuts, its either done right or not. Body work can be fixed 90% of the time. Then prime, seal, paint. No real two ways around it. If you want some magic answer or solution, you can search until your fingers are numb, but there is none.
What I can tell you is, do some research. Find out about single stage paints and 2 stage paints. Then find out what you have. If you have a single stage paint you can buff it out with a good rotary/or DA and some compound to get red of the white film oxidation.
Once you get it to where you want it you can try your hand at spot painting and blending but there are no guarantees on how it will turn out especially if you are an amateur with body work/paint.
FormulasOnly
Jul 23, 2018 08:47 AM
starliner
Feb 9, 2016 08:18 PM
1992Z28!
Nov 19, 2015 07:33 AM
Nervous2
Oct 8, 2015 10:53 PM
