Hatch pull down motor and OEM lock housing
Old Dec 13, 2011 | 12:41 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I bought an OEM trunk lock which I wanted to install. But as I compaired the lock to the clearance of the pull down motor frame, I noticed that there may not be any room to install the lock cylinder with the lock cable. The picture below explaint what I mean about the clearance issue. So can somebody tell me if they are using the lock cylinder along with the lock cable? If so, how is it routed (black cable). Do you have pictures of your setup? Thanks...
OEM lock cylinder
1323757989.jpg?t=1323758037
No clearance
1323757888.jpg?t=1323758047
OEM lock Cylinder ( Barely having clearance)
1323758039.jpg?t=1323758067
Old Dec 29, 2011 | 10:00 PM
Re: Hatch pull down motor and OEM lock housing
anyone?
Old Dec 30, 2011 | 12:46 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
it routes to the pass side the cable if you cant get the plastic piece in remove the 3 bolts that hold the pulldown to the car then put it in then bolt it back up heres 2 pics of what it looks like in my car 1 is with motor down and 1 iw when it is up
Attached Thumbnails Hatch pull down motor and OEM lock housing-imag0013.jpg   Hatch pull down motor and OEM lock housing-imag0010.jpg
Old Dec 30, 2011 | 01:27 AM
You are the man!!!! Thanks for taking the time to take a picture of your lock mechanism. Again,
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
NBrehm
Aug 5, 2015 07:57 PM
