how to replace the weatherstripping along the bottom of the door
Old Dec 30, 2011 | 11:20 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
does anyone have an tips or tricks on how to replace these? they are the ones that go around the sides and bottom of the door and have pins in them, do i need to add adhesive to them or can i just push the pins in and leave them?
Old Dec 30, 2011 | 11:40 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: how to replace the weatherstripping along the bottom of the door
Rip the old ones off and clean up the adhesive residue off the top of the door on both ends where the old one was.
Put the new one on and use 3M weatherstripping adhesive on the ends. There's a couple of push pins on the latch end of the door that might need to be re-used if your new pieces don't come with new ones. The rest of the strip has built in plastic push pins that line up with the holes on the door.
Old Dec 30, 2011 | 11:57 PM
Engine: L31 350
so the only peices needing the adhesive are the ends?
Old Dec 31, 2011 | 07:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd put a dab wherever GM did.
JamesC
Old Dec 31, 2011 | 07:53 AM
FYRCHKN's Avatar
Engine: LT-1
Yes, the ends are the only places they were glued on the two cars that I've replaced them on.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
