Door hing problem
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
Door hing problem
hey all
i have a problem with my door ( driver side )
there is a kind off check link that is coming loose.
i just replaced the hing and pin's last year.
i don't can't find any part to fix it.
can anyone help me with it??
Axle/Gears: 3.45, 3.27, 3.27
Re: Door hing problem
The door detent bar is part of the door side of the lower hinge. If the pin is bad you can repair it like the previous owner of my Firebird did by grinding off the head, punching out the pin and using s nut and bolt. Trust me, the repair looks crappy and the bar jumps and pops as it rides on the door detent roller. The best repair would be to install a new rivet and bar. But it is a swaged rivet and the average guy isn't going to have a hydraulic press that they can fit into that spot to squeeze the rivet. You could simulate it by grinding off the botom of a good rivet from a donor car, then install it in the new bar and weld a washer to the rivet. Grind it smooth, then paint it to match the hinge and it will look much like the old formed rivet.
Lon
Lon
Car: 83 Z28 T-top
Engine: 350 carb'd
You will want to double check, but I believe in my Classic catalog that the hinge is available to be replaced. You can also try some of Lon's suggestions, I know they are much cheaper than the hinge. I believe the hinge itself was in the $100+ range.
Car: '87 Firebird Trans Am
Engine: 5.7L, 350 V8
Transmission: Automatic
Lon
Lon
The detent bar is part of the door half of the hinge. That half is welded to the door. GM makes a replacement hinge that would solve your problem. However it involves a bit of work to install and is expensive. You have to drill out the existing sotwelds that hold the hinge to the door. The repair hinge includes a template that you use to drill new holes to bolt on the hinge. There is a threaded plate that goes inside the door shell then the hinge bolts to the door.
So long as the detent bar pin is ont damaged you may be able to straighten the detent bar with a couple of clamps.
Lon
Lon
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
