Sherwin Williams vs PPG
Old Feb 21, 2012 | 09:24 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
Starting to do all the due diligence on getting the paint done and Ive spoken to several local shops all split down the middle with some going with sherwin and others PPG. Prior to that end of things I was going to go with PPG as Ive just heard good things while researching. However, most of that research was in old posts, so... Which is better? Considering I would use the high end of either one.
With that said I also need suggestions on the best etching primer and primer/sealer as im going back to bare metal (ground up)
Thanks.
Old Feb 22, 2012 | 07:09 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: Sherwin Williams vs PPG
I've shot both, and both are good. I used SW Ultra 7000 years ago and liked it. I also used the Deltron system from PPG. Both will give you excellent results if applied properly. Can't go wrong with either. Look up AutoColor and Dupont as well if their available in your area.
Same goes for etch primers. Pick one from any recognized company and you can't loose. Look at Marhyde and Evercoat for two part primers. They may be more reasonable than the paint manufacturers and are compatable with most. I'm on an Evercoat Uro-fill lately. Easy to apply, sandable, and you can get it for bare metal applications. $100 per gallon including the hardener from my local guy. I've also used Marhyde 2K and liked it. It's a bit harder to sand, IMO, but good nevertheless.
Old Mar 3, 2012 | 11:49 PM
Engine: 355
Im not sure why Gmail isnt showing up half of the replies to my posts...
I actually decided on the Dupont, the color I want, however, only comes in their waterborne Cromax line here in California at $700 a gallon. So the supplies will be about $400 more than I originally thought (via PPG urethane)
Old Mar 11, 2012 | 09:10 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Have you looked into Sikkens? They have an outstanding product.
Hawk312
Aug 22, 2017 08:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
ws6transam
May 13, 2003 08:15 AM
gcore45
Feb 26, 2002 08:57 AM
Jim85IROC
Sep 6, 2001 11:32 AM
