2 questions
Old Apr 3, 2012 | 06:51 AM
slinger129's Avatar
Car: 1985 iroc
2 questions
first im replacing the center metal ttop piece on the roof and was wondering what do i put under it to seal it from leaking?does it go all the way around it to seal it?
next im replacing the 305tpi with a 383 carb do i have to replace all the fuel line setup(pump setup) since there is 2 lines to the front for return and gas?very much
Old Apr 3, 2012 | 08:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 2 questions
When I replaced mine,I cut a thin piece of of rubber gasket(to form) and used 3M weatherstripping adhesive under it,working well."Knock on Wood"
Don't know about the fuel line.
Old Apr 4, 2012 | 05:03 AM
slinger129's Avatar
Car: 1985 iroc
Re: 2 questions
thanks
Old Apr 6, 2012 | 03:25 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: 2 questions
for the fuel lines most people are either adapting there lines to a return style pressure regulator or extending the tube to the fuel pump further and running an engine mounted fuel pump with adapted lines or a low pressure in line electric fuel pump and some adapting of lines.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
