Power window question
Car: 1982 Z28
Engine: 383
Transmission: TCI TH350
Axle/Gears: 3.23 Posi
I picked up a replacement door for my camaro and the window is up. This is a power door. There are 2 wires coming from the power window motor. How would I get the window down without a switch while the door is out of the car being prepped? Can I just connect one of the wires to +12V to roll it down?
Thanks in advance.
Thanks in advance.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Power window question
Sure,connect a battery to it,1 hot,1 ground and tap the leads with the hot wire,ground the door to the battery.
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
it is doesnt work the first time reverse the leads as one way is up the other down
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
