Need info/pics to help about my floorboards
Old Apr 10, 2012 | 10:52 AM
Silky_Camaro's Avatar
Car: 1983 Camaro Z28 Crossfire injection
Engine: 305 5.0 litre crossfire
Axle/Gears: not sure, but it has POSI
I have a 1983 z28 with a real bad floor pan problem. Rust where the back seats go and where the rear axel linkage arm attaches to went to crap so that arm is no longer attached to the floor. is it worth replacing and if so how hard would it be and would i need a donor car or can use sheet metal?
Old Apr 10, 2012 | 03:59 PM
brandanpyles's Avatar
Re: Need info/pics to help about my floorboards
my front floor looks like that lol. i dont c y not u can get floor boards just about anywhere anymore. i might end up replacing my rear frame rails also
Old Apr 11, 2012 | 12:21 AM
83RecaroTA's Avatar
Car: 1983 Recaro T/A / 1988 GTA
Engine: 305ci Crossfire LU5 / 305 TPI LB9
Transmission: 700R4 / T5
Axle/Gears: 10 bolt posi 3.23 /
Kind of scary seeing the LCA mount area that rotted.
The LCA mount is a major structural component. If you cant repair that area properly it will not be safe to drive.
The problem is the stamped floor pans they sell do not extend back that far. You will have to cut what you need out of a donor car or fabricate it if possible.
Not sure what else I can tell you. What did you need pictures of?
Old Apr 11, 2012 | 03:05 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
My 85 was the same thing but not that bad. I fixed it as best as I could by welding in new metal but it was ultimately a waste of time as it was never the same again. Its up to you if you think its saving but I dont see it worth it unless the rest of the car is spotless
loud91rs
Oct 5, 2015 10:05 PM
theshackle
Aug 31, 2015 10:47 AM
Momar
Dec 6, 2003 02:19 AM
my84firebird
Oct 6, 2003 07:46 PM
Matto'85TA
Apr 14, 2003 11:42 AM
