Mystery access panel under the cowl?
Old Apr 29, 2012 | 07:36 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I was poking around under the dash of the 88 today, to get the pedals, brake booster and M/C out, and the last shred of the dash insulation whomever left back there out as well. I discovered something I think is pretty weird. Under the extreme driver's side of the cowl, on the bottom, there seems to be a place where an access panel USED to be (it's not there now). You can see the underside of the left windshield wiper transmission through the hole! No, it wasn't cut by the PO (whichever one did it), it's factory. The edge is smooth, the outline of the panel is molded into the body sealer, and there are the same nuts welded into the sheet metal just like under the rear seats (where the lower seat bolts go into). I'm missing the panel and 3 out of the 4 screws. Has anyone heard of this and/or can get me one before I come out one day and end up with rain water in the floor (which has already been replaced)?
I have a pic in my cam of this thing, and I'll get it up soon...
Old Apr 29, 2012 | 08:08 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Mystery access panel under the cowl?
Pic:
Old Apr 29, 2012 | 08:17 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
That looks like the cowl vent. There should have been a vent in there...
Old Apr 29, 2012 | 08:19 PM
Engine: 2.7L V6
Axle/Gears: 4.41
That's on the passenger's side. I have the vent for it but it's not in there. What is in the pic is on the other side of the car, facing upwards and not towards the engine. Which is the confusing part since I've never seen anything like this before.
:edit: If there IS a vent there, could someone get a pic so I know what to look for?
Old Apr 29, 2012 | 09:36 PM
cdoyle's Avatar
Was your car a non A/C car?
My 84 had that exact same thing, and there should be a vent there that is controlled by some pull cables under the steering column.
Here is a pic of what that vent looks like .
Old Apr 29, 2012 | 10:03 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Yes, according to the RPO sheet that was in the console, and also according to the heater pipe that was in the car, the car had the C41 heat without A/C option. But no dash parts, so that's why the thing is gone. I'll need to make a plate to cover it since I plan on running the C60 A/C heater system (without A/C) that only has the one vent. Still makes me that the stuff is all missing to plug these holes.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
kkirch15
Sep 30, 2015 04:44 PM
Gordonr1973
Sep 29, 2015 11:59 AM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
