Cat fight on my hood What should I do? Non 3rd gen
Old Oct 14, 2000 | 04:09 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I came home and there appears to have been a cat fight on my hood, They are only surface scratches do you thing that hand glacie (spelling) would work?
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Oct 14, 2000 | 05:12 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Try polishing compound, and if that doesn't get them out, try rubbing compound. When your done, wax that area.
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
[This message has been edited by IROCZTWENTYGR8 (edited October 14, 2000).]
Old Oct 14, 2000 | 08:07 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Buff it out with Meguires Heavy cut cleaner. Afterwards use Meguires swirl remover. Should be as good as new.
Bob
Old Oct 15, 2000 | 12:01 AM
BLACK Z's Avatar
Car: 86 Z28
What is swirl remover? is it a wax? After I use it do I need to wax the car? I don't dare touch a buffer, I did it to a old winter rider and I did alright but some spots I really messed up the paint.
Old Oct 15, 2000 | 09:00 PM
RCR's Avatar
RCR
Swirl remover is a very fine polish that removes the swirl marks left after buffing. It's a lot harder to do it by hand, but it can be done.
[This message has been edited by RCR (edited October 15, 2000).]
Old Oct 16, 2000 | 06:47 AM
BLACK Z's Avatar
Car: 86 Z28
What about gm swirl remover? I was also told to use 3m swirl remover, Is one better then the other? I Am not a body man I don't want to make the paint worse. Would I just rub it intil incame out? thanks
Frozer!!!
Jan 19, 2024 04:55 PM
neekolzun
Aug 24, 2015 04:59 PM
Out-Cast
Aug 22, 2015 07:49 PM
reiderz iroc
Aug 13, 2015 04:57 PM
