Door Lock Assembly
Old Oct 27, 2000 | 11:07 PM
Topgun's Avatar
Door Lock Assembly
Question,
I have an 84' Z28, my Drivers door lock assembly is screwed up, ok. Will a Door Lock Assembly off a base model third gen work? I need the info by tommorow as i am going to the junk yard where they have a base model. And see if i can get the assembly off that car. so, are they interchangable? Thanks for all the info that you can give me.
EMAIL: CTopgun5@aol.com
_______
84' Z28
New 350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
180º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9's KFC-6906S
New Pioneer Sub TS-W253C
New Jensen 4-Channel Amp XA-4150
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
Old Oct 29, 2000 | 11:00 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
The locks are the same. If your orginial lock is just hanging up you can take it to your local GM dealership and they should be able to rebuild it. My local dealership has rebuilt my driver's before. You may also want to try spraying some WD 40 into the lock itself. The dealership can also rekey the lock so it will work with your orginial key so you won't have to carry around an extra key.
"5 out of 4 people have a problem with fractions"
My Camaro: http://home.earthlink.net/~singleton052095
Old Oct 29, 2000 | 02:07 PM
Wolfcoast's Avatar
Never use WD-40 on the lock mechanism itself where the key goes. The wd-40 will attract dust & dirt and gum up the lock. Always use a graphite powder lubricant on the lock. It won't attract the dirt and your lock will work much better.
Randy
84 Trans AM LG4, 700R4 T-tops
1984 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
Old Oct 29, 2000 | 09:18 PM
Topgun's Avatar
The lock Assembly is not the lock. It's the part where the catch is. Anyways, it's broken, non repairable, i have allready looked at it. Where the Catch is, is totally broken, the spring and the whole right side of the assembley is coming off. Thats why i was going to replace it. Tues or wneds are my days off, and i will play with it then. I really hate getting in on the pass side!!!
_______
84' Z28
4 BBl Carb
180º Thermostat
700R4 Trans
Charcol in Color
no T-tops, but wish
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Night rider327
Sep 2, 2015 04:18 AM
