Aftermarket Steering Wheel on Airbag Cars
Old Nov 2, 2000 | 03:05 PM
Mike 25th's Avatar
Me and GOFASTER would like to know how to go about finding a column kit for cars that came equipped with airbags.
Will the 89 and older kits work?
How does the steering wheel come apart?
I've seen it done, so I don't want to hear any lip
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
My T-Rammed L98
Old Nov 2, 2000 | 05:51 PM
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Hey Mike,
I am currently installing an after market wheel on my 1990 Z.
Ensure that you disconnect the positve battery terminal. Then remove the panel under neath the dash. There is a "yellow" wire that you also must detatch to deactive the airbag. Then removing the wheel is easy. There are two bolts on the reverside of the steering wheel. You will need a sterring wheel puller though. I have yet to start on mine though.
I have also heard that the air bag symbol will stay on since the circuit will not be closed becuase of the absence of the air bag.....if that's tru..then that sucks!
tommy
Old Nov 2, 2000 | 07:21 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
My SIR warning light stayed on since I bought my car,so I disabled the SIR circuit and the warning light went off.So if you disable it at the right point,the warning light shouldn't come on.
Jorlain
Aug 24, 2022 05:11 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
