Hatch leak.
Old Nov 3, 2000 | 07:41 AM
HIX5000's Avatar
Hatch leak.
My rear hatch leaks back where the shocks meet the hatch. The water comes in between the hatch and the seal theres no holes in the seal and it's in good shape. Any one else have this problem?
1988 Camaro RS
2.8L five speed
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
Old Nov 3, 2000 | 01:48 PM
Chet's Avatar
Car: GTA
You can try and rub some kind water repellent gel on the seals. I justed used some valsoline and mine stopped leaking. I've heard this also works of T-tops.
Old Nov 3, 2000 | 02:20 PM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
I had this problem too, but now its fixed. On the outside of the hatch (with it closed), look at where the body color painted metal at the back of the car meets the glass. Down in that crack there is a seal that is usually dry-rotted and doesn't work after years of changing weather. The water is most likely coming in there. Run a thick bead of clear silicone RTV sealer between the glass and metal all along the edge where they meet to seal it up. make sure to seal it all the way down to the sides, but wipe any excess off ASAP. Hope this solves your problem.
John
84 Firebird with Trans am ground effects- 350 4bbl GM crate motor (LM1), T-Tops, automatic, K&N filter, 180* thermostat, ram-air hood scoop, flowmaster muffler, Accel cap & rotor, MSD Super Conductor Wires. Coming soon: new interior (grey), rear end work, subframe connectors, polyurethane bushings
jrdturbo
Mar 31, 2016 02:58 PM
HoosierinWA
Oct 7, 2015 10:15 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
