powerdoor locks dilema
Old Nov 19, 2000 | 08:37 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
my power locks work with the door panel off,but not with it on.the wire must be sticking where the door panel touches the plastic.theres no where else to put it.I can put a shield around the wire push rod but that would put a bulge in my door panels.does anyone here have a good way to solve this?
Old Nov 20, 2000 | 01:38 PM
evilho7810's Avatar
This happened to my friends formula the door lock accuator was too weak and needed to be replaced.
Old Nov 20, 2000 | 02:55 PM
jason86/2.8's Avatar
Funny thing about my PDL is that when I hit the lock button on the drivers side, it'll lock the passengers side on the first try but I have to hit it 3-4 times for it to lock the drivers side. I'm just glad I have that little slide door lock too so I don't have to hassle w/ it.
1986 Berlinetta, 2.8L, newly rebuilt 700R4, 3.42 Posi. 131K miles and counting, K&N air filters.
Old Nov 20, 2000 | 05:20 PM
TexasLT1's Avatar
Car: '92 RS
mine has the exact same problem, passenger locks immediately, driver takes a couple of times. My passenger door did that for a while. Finally, I just took off the dorr panel, shot a lot of WD40 up in there, and it has worked fine since. need to do that to my driver door now
Old Nov 20, 2000 | 09:52 PM
Engine: 2.2
texas,what parts did you oil?
I recomend you use silicone lube next time,as it is resistant to moisure common in the doors.
Old Nov 21, 2000 | 04:25 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Junkyard:
WD in WD-40 stands for water dispersion. It was originally designed as a rust inhibitor, but will work perfectly to clean the contacts and keep the rust or corrosion at bay (for a while). Silicone will float on rust or moisture, and won't work as well, and will insulate a poor electrical connection. I have the same problem with my locks, so I'm just gonna douse them both.
Good luck
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
