Cowl screen
Old Jun 15, 2012 | 11:48 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Cowl screen
Anyone got any tips to readhere the mesh iside the plastic cowl? I had mine stored away and for some reason one whole side of the mesh just fell out. And the other is starting too. I tried superglue, nothing. Liquid nails, no. Im thinking maybe a hot glue gun. The factory looks like they may habe slightly melted the surrounding plastic to hold the mesh. Im at a loss. Im so terrible when it comes to body restoration stuff it isnt funny, mechanical is another story.... Thank you anyone . Take care.
Old Jun 15, 2012 | 02:31 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Cowl screen
I would think these would be a dime a dozen and readily available at any junkyard...wouldn't be surprised if they were all the same from 1982-92. I'd go that route before trying to fix yours.
Old Jun 15, 2012 | 03:01 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Re: Cowl screen
I have seen lots of the cowl screens available right on ebay.
Old Jun 15, 2012 | 03:26 PM
82tarecaro's Avatar
Re: Cowl screen
The original looked like it was melted in place. There is probably not a good way to fix it. There should be plenty of them around.
Old Jun 15, 2012 | 03:52 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: Cowl screen
I think the material is a polyolefin which doesn't like to be glued without some type of special primer or activator. An actual hot melt would work but not a hot glue gun. Best bet is to just pick up another one.
Old Jun 15, 2012 | 04:21 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Re: Cowl screen
Use 3M Super Weatherstip adhesive part number 8001, works like a charm
Old Jun 15, 2012 | 06:04 PM
TheEndofanEra's Avatar
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
Re: Cowl screen
I hate to say it but they're different, at least they are between 85
Sport Coupe and a 92 RS. So 82-86 base models, at least are different from 86--92 IROCs and Z28/RSs.
Old Jun 15, 2012 | 06:09 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Cowl screen
That 3m is good stuff.
Old Jun 15, 2012 | 09:20 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Re: Cowl screen
I was going to buy one from thirdgen ranch but it doesnt list the year just 82-92. I may rry that 3m stuff. Autozone or advanced have it? It needs to harden and dry instantly it seems as the mesh is tought a little ans will pull away from the edges. I cant believe this i just pulled my buddies monte 350 swapped the cam, and im like i have two left hands when it comes to anything like paint or resto stuff. Its a ioke. Thanks though for the responses. Did the search there is nothing on the subject incredibly, as these things are so delicate.
Old Jun 15, 2012 | 10:09 PM
Re: Cowl screen
I had the screen on mine sagging at the high spots, I used a hot glue gun to readhere it, and so far it's working okay. Granted, it hasn't seen much in the way of real weather, just 65 in the garage and a couple of 90+ days out in the sun, but it hasn't failed yet lol
Old Jun 17, 2012 | 06:51 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Re: Cowl screen
Well the hot glue gun worked like a charm. Definatly the way to go. Little messy but you dont see it anyway. Held it well. Thanks
Old Jun 17, 2012 | 07:38 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Cowl screen
just yesterday i had mine off . used a hot glue gun on the screen . seemed to work very well , time will tell . also took time to clean & spray paint cavity under screen . i also took time to re-paint entire cowl shelf flat black . WOW , what a difference . take time to really clean surfaces well before glue/paint . worked well for me , i'm happy . good luck .
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Eric-86sc
Sep 28, 2015 11:37 AM
