Hood Wont Open
Old Dec 14, 2000 | 08:54 PM
DROPZTOP89's Avatar
Hood Wont Open
I recently went out to check my oil and got an unpleasant suprise...the hood would not open on my 89 Formula. I cant remember where I saw this topic recently so any help on how to get it open and keep it opening is appreciated.
Old Dec 15, 2000 | 05:44 AM
327 firebird's Avatar
This may sound very untechnical but this happens from time to time with me. What I do is pull the hood release then go to about where the hood latches in the front and hit it a few times firmly (but not too hard to damage the hood or paint) It usually pops up. After its up WD-40 the hood latch and maye clean it!! The release mechinisim gets sticky sometimes. If this doesn't work you can get under the car and pull the release manually and it will pop up.
Old Dec 15, 2000 | 10:40 AM
Daniel's Avatar
i had the same problem on my 89 iroc. tapping the hood wouldn't work either. i then added an extra spring under the hood next to the original spring and it fixed the problem. all it took to open the hood after pulling the release was a slight tap on the middle.
wow, this is my first post here, but a long time visitor.
Danny "clueless"
'89 Iroc-z28
5.7 automatic
all stock
Old Dec 15, 2000 | 06:35 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I have the same problem too, all I do though, is grab the hood right in front of the front light, and give it a good yank. It just about always comes up, if it doesn't, I push the hood back down, so it latches, and then I pull the hood release again..
Houston f-body Member Page
Home Page (and pics of my car too!)
1989 305 tbi Camaro RS Red/Red
Flowmasters
K&N
Old Dec 17, 2000 | 02:15 PM
dude12387's Avatar
same problem, same responce, hit it lightly, then go to GM and get a new spring for $2.
Old Dec 17, 2000 | 04:03 PM
DROPZTOP89's Avatar
Thanks for the help, Ill give it all a shot, then replace the spring.
Hotrodboba400
Dec 10, 2019 07:07 PM
neilb
Sep 15, 2015 05:06 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
