Headlight Pop-up Solenoid Juice???
Old Jan 20, 2001 | 08:47 PM
Don Christensen's Avatar
Car: 1989 Formula - Red
Transmission: 700 R4
Axle/Gears: 3.73 Posi
What is the stuff that they put inside the Headlight Pop-up Solenoids? GM wants $250 apiece for new ones.
The only thing wrong is that the "friction material" inside them is ground up too finely and they slip when they try to pump up.
Does anyone know what this stuff is??
Old Jan 21, 2001 | 01:25 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Make it easy on yourself. Go to the junkyard. It may take a while, but it will be worth it. Plus, all of the other stuff that you can get too.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 21, 2001 | 09:22 PM
Thanks STINGERSSX.
I had tried the junk yards and they didn't have em. Then, last night I figured out how to fix em', and a friend who works at Auto Zone confirmed this...
Auto Zone sells a Siemen's Window Lift Gear Kit for Ford Power Windows that uses three hard-plastic spacers. These spacers are the same plastic spacers that Pontiac uses in the Pop-up solenoids. These spacers are the part that almost always breaks/wears out. The kit is part #84634 and they are about $23 each. Both solenoids now work perfectly. But thanks!!!!!!
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
JSDaddy189
Sep 26, 2015 03:50 PM
