Questions about switching dash set up.
Old Jan 25, 2001 | 01:12 AM
Jims83TA's Avatar
Hi. I was wondering if I could remove my whole dash from my 1983 TA, and install one from either a 1987 or 1988 TA/firebird/or formula. I want to remove all the gauges and everything, and install the whole new dash. I have a 1988 and 1987 in which i could remove the dash setups from. After the switch, would the gauges still work? What parts do I need to make the switch successful? Please help me out, and let me know if you or anybody you know have already done this. Thanks.
James
1983 Trans Am
Old Jan 25, 2001 | 06:47 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
There is an article in the Tech section about doing that exact swap, although I think it was done with a Camaro... I am going to be switching dashboards out of my 85 with one from an 87 as soon as I get the parts that were outlined in that article.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Jan 25, 2001 | 10:46 AM
Jims83TA's Avatar
Thanks for the help. One question though, would it make a difference if the new dash and gauges were from a firebird, eventhough my car is a Trans am??? Please help me.
Old Jan 25, 2001 | 11:37 AM
mike88RS's Avatar
trans am and firebird gauges shold be the same as long as they are from a V8 car. the sending units may be different, as well as VSS vs speedo cable
good luck, that would be a killer swap
i myself have always wanted the GTA digital in my camaro
Old Jan 25, 2001 | 11:48 AM
Jims83TA's Avatar
Thanks. Well the problem is that the firebird is a 6 cylinder, while my TA is an 8. Will this cause any problems? Will i still be able to switch the gauges and dash? If not then i can get them from an '88 formula, which is a V8. Thanks.
Old Jan 25, 2001 | 02:45 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Tachometers are cylinder specific. The V6 tach will not read right in a V8 car.
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
