How hard are rear louvers to put on a non louver rear window????
Old Jan 28, 2001 | 12:25 PM
86IROCMIKE's Avatar
If I can find one,do I have to drill through the glass or what?????What do I need????????
86 IROC,canary yellow(originally black),fully loaded.305TPI WITH 700R4/SHIFT KIT,2:73 POSI REAR,4 WHEEL DISC BRAKES,T-TOPS,POWER LOCKS,POWER WINDOWS,TILT,CRUISE,SADDLE INTERIOR,POWER ANTENNAE,SPOILER OFF 87 IROC SO NO THIRD BRAKE LIGHT ON ROOF,16" BY 8" RIMS OFF 89 IROC,3"INCH EXHAUST WITH A 2 CHAMBER FLOWMASTER AND 3 1/2" BY 18" LONG CHROME TIPS,20% TINT ON SIDES,HATCH AND T-TOPS,GTS TAILLIGHT COVERS,AFTERMARKET FOG LIGHTS,PIONEER CD RECIEVER WITH REMOTE AND DETACHABLE FACEPLATE,WITH JENSON SPEAKERS ALL AROUND,TALKING RADAR DETECTOR"BACON ALERT"
....Long live the EIGHTIES!!!
Old Jan 28, 2001 | 12:26 PM
Josh 91RS's Avatar
Please dont put louvers on puke!
Old Jan 28, 2001 | 01:32 PM
Lov2xlr8's Avatar
you need the clips that go on the perimiter of the glass, the have slots that the lovor snaps into. If you buy one new you get them if not look around, if I can get mine off and you ned them I will give them to you. Let me know and I will try to get mine off. I dont have lovors but my car used to so the clips are still on the glass.
Teach your children the dangers of Rice......88 RS 3.4L 2000 BMW silver. Black and grey interior.
Old Jan 28, 2001 | 01:33 PM
89IrocZZ3's Avatar
The ones I had a few years back(the window is tinted now) on my iroc came with two hinges for the top that hooked onto the edge of the glass and stayed in place with double-sided tape it also had 4 clips 2 on each side that clipped onto the edge of the glass and 4 posts underneath that were adjustable to keep pressure on the louver to keep it tight.
No drilling required!!!
BTW
I'm with Josh just tint the window.
Old Jan 28, 2001 | 09:06 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
There are a few different types out there. I just put a factory set on my car and it had clips that slide over the edges of the window, 2 at the top with double sided tape, 2 on each side that just slide on and 2 at the bottom that stick only to the window.
Another set I used to have had a metal strip that required the 4 bolts that hold the glas in be removed and the metal strip went under the heads. There were 4 screws connected to that metal strip. The Louvers screwed onto those at the top and connected to a slide on clip, one on each side.
My recommendation would be to find a factory styled set. The other kind can shatter the back window if you over tighten the bolts and hit a pot hole or drop the rear window too hard.
By the way, I still loke the looks of louvers. That's why I just put a set on my car!
87 IROC 350 TPI with less than 10k original miles
www.users.uswest.net/~smoyer/iroc.htm
Old Feb 1, 2001 | 11:55 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Originally posted by Lov2xlr8:
...if I can get mine off and you ned them I will give them to you. Let me know and I will try to get mine off.
Lov2xlr8 - please e-mail me... Thanks...
KAM
86IROCMIKE - just noticed you're up in Leonardtown - I'm just down the road in Lex Park...
[This message has been edited by thunderstick (edited February 01, 2001).]
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
draco
Oct 4, 2015 09:25 PM
