T-Top Rust
Old Aug 12, 2012 | 03:58 PM
imelmo's Avatar
T-Top Rust
What would be the best way to address this? I'm thinking get it blasted with a small sand or media blaster, then some rust converter/primer. From the looks of it there is supposed to be some weather stripping or something over it. Is that the case?
Surprisingly the t-tops do not leak but I want to stop the rust before it gets any worse.
Old Aug 15, 2012 | 09:51 PM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Re: T-Top Rust
Blast it. Anything rotted through cut out and replace.
Old Aug 15, 2012 | 09:54 PM
jas2730's Avatar
Re: T-Top Rust
Have you removed your center bar to see what's hiding under it?
Old Aug 15, 2012 | 10:54 PM
imelmo's Avatar
Re: T-Top Rust
No, not yet.
Old Aug 17, 2012 | 03:06 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: T-Top Rust
Originally Posted by imelmo
No, not yet.
I would recommend removing the t-top bar for sure, my rails looked like yours, and my car had some pretty serious rust under the t-top bar (which came off in about 10 sections).
Old Aug 19, 2012 | 05:01 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
Re: T-Top Rust
Yeah , your not going to like this but with that much rust showing your going to have to pull all that rubber out of there because I bet that underneath all that nice rubber there is a rust field. Im restoring an 87 and mine was not showing as bad as yours but as soon as I took all the rubber out and the center bar whoa !!!! surprize surprize. But all of my car is going to the metal so was not a big issue.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
