how do you remove the rear seat back???
Old Mar 6, 2001 | 07:11 PM
ripyaone's Avatar
I'm installing new carpet and I have everything out except the rear seat back.
I can't find and screws or bolts holding it in,just the 2 pivot points. thanks
Old Mar 6, 2001 | 08:25 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Theres a nut on the outside bottom corner of the seats(lower right side for drivers, lower left side for pass). I think it's 13mm. Undo that then pull the seat towards the outside to get it off the pivot rod. real easy, just sometimes the nut is hidden by the fabric
1985 ASCD Ram Air Trans Am
http://www.execpc.com/~karpsta/home.html
to find out more
-=ICON Motorsports=-
Old Mar 6, 2001 | 08:52 PM
ripyaone's Avatar
Thanks for you help
Old Mar 6, 2001 | 10:00 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You didn't say if you have a solid rear seat back or a split style. They both have a hinge that is mounted to the seat back with a threaded stud pointing down. It has a 13 mm nut attaching to it from below. You have to remove the bottom seat cushions first to ge to the nut. The solid rear bench has just the two hinge bolts to be removed. The split bench style is removed by removing the nut, then twisting the seat back while folding it forward. This gives you clearance to pull it off the post that is welded to the center hump. I hope this helps, Lon.
Frozer!!!
Jan 19, 2024 04:55 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
