Strut Tower Rust
Old Sep 29, 2012 | 03:32 PM
Col1989's Avatar
Strut Tower Rust
Hey guys, I really need your opinions on this issue I'm having. There is a rust hole near the strut tower on the drivers side of my car. I need some opinions as to what I should do with this. Such as bringing it to a body shop or if its even worth saving. The link I've provided has pictures of the rust hole. Thanks in advance
http://s1285.photobucket.com/albums/...989/?start=all
Old Sep 29, 2012 | 07:24 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Strut Tower Rust
that spot is fixable . i would be concerned if there are other areas like it . rust/corrosion is like cancer . needs to be removed or properly treated . get car on a lift and inspect ENTIRE under body . i expect you might find more (hope you do not) . good luck .
Old Sep 29, 2012 | 07:37 PM
Col1989's Avatar
I have had a look under the car and there is rust in certain places but with a good amount of work, most of it can be repaired. But now I'm left with two questions. 1) how much do you think it would cost to have a body shop patch that? 2) I have surface rust along the upper portion of the wheel well, would I be able to clean it up and coat it with rust bullet
Old Sep 29, 2012 | 10:51 PM
UNCLE TOM's Avatar
too many unknown variables , a body shop in downtown L.A. , boston , N.Y.C. , seattle ??? backwoods ms. (where i live) or any other place off the beaten track . just take it to the shop you deal with and get an estimate , be prepared to pay 25-50% over estimate . good luck .
Old Sep 30, 2012 | 11:33 AM
Col1989's Avatar
I guess I'll just shop around and see what happens. Thanks for the help, when I get the work done I'll be sure to post some pics.
Old Oct 3, 2012 | 07:17 PM
blakecharles's Avatar
it can be fixed. I would wire wheel all the crap outta the wheel wells and inspect the whole thing.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
