Window guide replacement - or not?
Old Apr 11, 2001 | 12:10 PM
Eric's Avatar
Car: 87 GTA
My windows rattle, the window on the drivers side won't seal properly (wind noise at the very front on the A-pillar) and the doors don't shut properly. Also, on each window at the very top are little "holes" that have benn worn through the tint, with little track marks down the length of the window, top to bottom.
I know that the felt has worn off the window guides, hence the tint being worn, but GM wants $25 a pop! I am not thrilled with the idea of spending $100, so I thought I might strip the felt off and replace it myself. Has anyone done this? If so, was there a particular felt you used, and most important what type of glue was used?
I am hoping that by fixing these and adjusting them properly that all my window woes will go away. Is that optimistic or what??!
87 GTA 350 TPI, 700R4,
K & N, Accel cap/rotor/wires, SLP airfoil, ported plenum
Old Apr 12, 2001 | 07:36 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Seems to me you could get those window guides from a bone yard... If not, there's a type of weather stripping (self adhesive) that would probably work rather well. It's the "pile" type (that's what it's called). I actually used it on the vertical window tracks in my doors, since the rubber inserts were missing for some odd reason... You should be able to get that at any hardware or home improvement store...
KAM
Old Apr 12, 2001 | 12:58 PM
purpleworm's Avatar
hey man don't feel bad!! I need the the out side ones and the dealer wants $103 a piece. It is a stupid piece of rubber you can get for 1/3 the price. How do you think I feel hahaha The only way to fix it is buy the stuff.
Old Apr 12, 2001 | 03:57 PM
HybridZ's Avatar
Car: 13' ZL1/91' Z28/10' Audi A5
Engine: 6.2L SC/5.7L 350/2.0L Turbo Quattro
Transmission: M6/700R4
The dealer wants $25.00 a piece?! I'd say buy them. Its costing me $80 bucks for the inner sweeps and $50 for the outer ones. And thats for each piece. $25 a piece is pretty decent considering its GM and it should last another 10+ years or so. JMO
SS 17x9.5 wheels,
HOTCHKIS 1"drop springs,
HOTCHKIS tower brace,
Bilstein struts and shocks,
K&N filters,
MSD 6A,
MSD 8.5mm Wires,
MSD Cap & Rotor,
Hypertech airfoil,
SLP intake runner (plennum not ported yet, soon)
High flow cats,
SPOHN panhard bar, lower control arms, and subframe connectors,
Baer front track system,
3" Flowmaster Exhaust System,
2100 Stall High Performance Torque Converter,
300 watt sound system,
and soon to come...ZZ4 crate motor...hopefully.
Old Apr 12, 2001 | 07:44 PM
Eric's Avatar
Car: 87 GTA
No, I am not talking about the sweeps (the long pieces that run the length of the door at the top) - I am talking about the steel guides on the top of the door. There are two of them on each door, on the inside of the glass at the top of the door - they basically right-angle steel brackets with felt on them that guide the window for in-out movement. The felt is toast and I was just wondering if anyone had ever stripped the factory stuff off and put on their own replacement felt. These brackets with felt are $25 from GM.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
pfsteichen
Feb 9, 2016 06:59 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
