I had to cut the wire going to it from inside the fender and now I can't push down the antenna
!!!!!!!!!!!!!!!Is it the motor,how much are replacements and hopw easy are they to install?????????CAN I PUSH THE ANTENNA DOWN MANUALLY??????
86 IROC,canary yellow(originally black),fully loaded.305TPI WITH 700R4/SHIFT KIT,3:73 POSI REAR,4 WHEEL DISC BRAKES,T-TOPS,POWER LOCKS,POWER WINDOWS,TILT,CRUISE,SADDLE INTERIOR,POWER ANTENNAE,SPOILER OFF 87 IROC SO NO THIRD BRAKE LIGHT ON ROOF,16" BY 8" RIMS OFF 89 IROC,3"INCH EXHAUST WITH A 2 CHAMBER FLOWMASTER AND 3 1/2" BY 18" LONG CHROME TIPS,20% TINT ON SIDES,HATCH AND T-TOPS,GTS TAILLIGHT COVERS,AFTERMARKET FOG LIGHTS,PIONEER 180 WATT CD RECIEVER AND DETACHABLE FACEPLATE,WITH JENSON SPEAKERS ALL AROUND,TALKING RADAR DETECTOR"BACON ALERT"
....Long live the EIGHTIES!!!and my love for the IROCZ
!!!!!!!!!!!!!!!Is it the motor,how much are replacements and hopw easy are they to install?????????CAN I PUSH THE ANTENNA DOWN MANUALLY??????------------------
Mike, I had the same problem with mine. The antenna mast has a nylon-plastic band at the bottom that wraps around a plastic piece inside the antenna motor assembly. On mine the plastic band (looks like a long cable tie with teeth) was broken, and since the antenna wouldn't go down the motor would just keep running - it couldn't sense the antenna was down so it kept pulling. I pulled the whole antenna assembly out (pain in the *** , but it does come out through the inner wheel well) and bought a new mast assembly from GM It was about $56. You probably can't push the antenna down because the band is jammed in the motor.
It's a pain, but not that difficult.
Good luck.
Eric
87 GTA 350 TPI, 700R4,
K & N, Accel cap/rotor/wires, SLP airfoil, ported plenum
Good luck.
Eric
