T-Top Weather Stripping Problem
Old Dec 2, 2012 | 09:06 AM
LedZep's Avatar
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
Hey guys, I'm replacing the weather stripping on my 1990 Formula and I can't figure out how to get that center bar off the car to clean it. I'm talking about the piece that has 2 channels on both sides and sticks up the furthest. If you are putting in the T-Tops this is the middle piece that the glass lip of the T-Top slides under. How do I remove this piece to clean it? It stands up even with the body, it's black and metal. If you need I can get a picture to show the piece, but I think you guys will know what I am talking about.
Old Dec 2, 2012 | 09:38 AM
ikik's Avatar
Re: T-Top Weather Stripping Problem
Hi go to this video on Youtube.com key in ( iroc z replace weatherstrip ) step by step remove weather strip.
Old Dec 2, 2012 | 09:42 AM
LedZep's Avatar
thanks
Old Dec 2, 2012 | 10:30 AM
LedZep's Avatar
he just ends up drilling out the screws due to corrosion, however I had the screws out and it seemed like the center pillar was stuck down to the car even after removing all screws. Does anyone else have any advice on this?
Old Dec 2, 2012 | 11:43 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Their is double sided tape also under there,used as a gasket.just make sure you have ALL the screws out.Maybe a little heat will help.
Old Dec 2, 2012 | 12:00 PM
LedZep's Avatar
that is kind of what I figured, I'll put a heat gun to it.
Do you guys know if I can put the weather stripping on during this type of temps, high in the mid 60s? Or do I need to wait until it gets warmer to put the new weather stripping in?
Old Dec 2, 2012 | 12:16 PM
mantaguy's Avatar
Engine: 5.0 EFI
I would guess you could,but warmer would be better.If you have to install it now,I would leave the car out in the sun if you don't have access to a garage you could heat up.
Old Dec 2, 2012 | 12:24 PM
LedZep's Avatar
thanks for the advice, I may be able to get it into a heated garage or basement.
Old Dec 2, 2012 | 12:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
Basement???
Old Dec 2, 2012 | 05:37 PM
LedZep's Avatar
I have friends with basements they use as garages, cement floors and can be heated.
Old Dec 3, 2012 | 05:26 PM
82tarecaro's Avatar
I should pop off with some persuasion. I pried mine off with a pry bar. But I had to get a new one because it was corroded. But it came off without bending or damage.
Old Dec 3, 2012 | 07:09 PM
LedZep's Avatar
It isn't corroded at all and as far as I know it has never been off
Old Jun 12, 2013 | 10:56 AM
LedZep's Avatar
What adhesive removers do yall recommend? A lot of people say 3M Adhesive Remover, but that basically looks like Goo Gone. Is there something better I can buy?
Old Jun 12, 2013 | 01:30 PM
mantaguy's Avatar
Engine: 5.0 EFI
I used Gasoline on some of the difficult spots,works good.
Old Jun 12, 2013 | 01:31 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
That 3M Adhesive remover works like a champ. Like insanely good. Be careful with the overspray.
1992 Trans Am
May 10, 2023 07:19 PM
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
LittleFranks
Sep 17, 2015 12:22 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
g.l.mos
Aug 22, 2015 12:02 AM
