S10 box for ac delete
Old Jan 4, 2013 | 10:45 PM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
Transmission: GTO T56
Axle/Gears: 3.73 S60
I bought an air box from a s10 pickup at the junkyard today. I have removed the ac system from my camaro and was hoping to use the s10 air box to keep the defroster working. I have been looking through past threads and I know it has been done, but i haven't been able to find any pictures or more detailed explanations. I was wondering if anyone can give me an idea of what modifications must be done, pictures would be great. I have attached a picture of the box. As much as I would like to buy an expensive aftermarket box its not an option for me right now. Thanks
Attached Thumbnails S10 box for ac delete-t2ec16jhjgqe9nomzlvsbqzkr0f2jw-60_35.jpg
Old Jan 6, 2013 | 10:05 PM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
Re: S10 box for ac delete
If anyone is interested I got it to work. Overall it ended up costing about $20. I used a hacksaw to notch out spaces for the left heater hose and the flex pipe that comes through the firewall behind the motor. I took the heater hose off temporarily to put the housing in place and screwed it into the firewall. Four screws was all I needed to get it flush and on there pretty tight. I then took a blank outlet cover and cut out a slot for the original resistor. I used the blower motor that came with the housing as well as the new connector. I clipped off the old connectors for the blower motor and coupled the purple and black wires. There is a spot on the bottom right that is a little close to the manifold, but there is enough of a gap that I don't think it will be a problem. If it is I may just put some sheet metal there, but I'll have to see how it goes.
Attached Thumbnails S10 box for ac delete-imag0172.jpg   S10 box for ac delete-imag0173.jpg   S10 box for ac delete-imag0176.jpg
83 Crossfire TA
Sep 18, 2015 12:01 PM
buckshot63
Sep 10, 2015 09:15 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
