Painting door handles and locks
Old May 21, 2001 | 11:35 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I was going to repaint my door handles and locks black and need some suggestions on prep work. Should I just tape around them, sand off the old paint, and start spraying? Or is there anything else I should do? Also, any tips on painting the rear hatch window trim?
[This message has been edited by BuckeyeROC (edited May 21, 2001).]
Old May 21, 2001 | 12:35 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I would consider disassembling everything. Clean with a degreaser. Scuff sand everything. Then use a good epoxy. Short of lots of taping, I'm not sure what to do about the hatch.
Old May 21, 2001 | 01:02 PM
86ZRICHIE's Avatar
Same thing for the hatch, just mask well to keep paint from hitting your car, or remove the hatch completely for the best results
Old May 21, 2001 | 02:11 PM
Apone's Avatar
Car: 1991 GTA
I repainted my hatch strip last summer. I didn't really prep anything at all, but mine came out really nice.
Basically, I sanded down the metal strip seeing as I had some rust and rough paint. Just be careful to keep the sand paper on the metal and not get it on your car! Just go slow like I did and you wil do fine.
Then after sanding, I give the entire strip a coat of rustoleum to help prevent any further rusting.
After the rustoleum dried, I applied a few coats of gloss black paint. I think this was also the rustoleum brand.
When I painted, I used those small foam brushed that you get at the hardware store for a dime. Just remember to go really slow and you will do just fine. It really makes your car look a hell of a lot better.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
