Anyone has the part # for the lower pin the holds the door?
Old May 28, 2001 | 11:42 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
My driver's door is really bad!I need that lower door pin part#, or is it better to just let a autobody shop fix it?
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 liter h/press. walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
Old May 28, 2001 | 11:44 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
you can go to the dealership or a body shop supply store and tell them what you have. they sell a kit, pin and bushings that you can install yourself. the job is kinda a PITA, but if you are mechcanily inclined, i am sure you can do it.
Wide Open Till You See God...Then Brake
Old May 29, 2001 | 12:07 AM
pookey's Avatar
my door is in need of attention to but I was told by 4 different shops that it would cost $400 to replace all the hinges.
88 White Formula 305 TBI With A New CD Stereo and Abolutly Nothing Else Done To It!
Old May 29, 2001 | 12:43 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Autozone, PepBoys & most all major part stores carry the HELP brand pin & bushing kit for around $6
Modifying anything with an engine, is always fun
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
BlackTopKing
Aug 19, 2015 12:13 PM
1nastygta
Aug 8, 2015 07:38 PM
