Installed the grant GT
Old May 28, 2001 | 04:06 PM
Camaro_hunter_d's Avatar
A much better looking steering wheel over the stock thing. It took around 45 minutes with a little bolt thread trouble but well worth it. I drive good so the airbag loss is not a prob. If you do do this swap take out the fuse, the yellow connecting wire at the base of the steering column. I got the painted silver type 4 spoke and it looks so much better....
Old May 28, 2001 | 04:20 PM
EVILFACE's Avatar
Kewl. I got the chrome Challenger wheel and it was a vast improvement over the stock wheel. Looks better and the thicker diameter feels better.
EVILFACE
88 Camaro
Stock 305 TBI Auto, Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element
Runs A Blistering 16.5 @ 81.5 mph (due to major tire spin)
http://www.evilface.com/evilscamaro.htm
Old May 29, 2001 | 12:55 PM
Chaotic Firehawk's Avatar
How hard was it to remoe the stock wheel and put on the new one?I'm considering getting a Grant wheel,just don't know how hard it wouldbe to put it on.
Chaotic Firehawk can be found wondering NEThirdgen.org and 3rdgen.org
"A musclecar, by definition, is a powerful and sporty vehicle that must be able to spin its tires at will. The Firebird Trans Am is capable of laying down twin black streaks of rubber several hundred feet long. We wanted to be sure it could, so we did it a half dozen times in the name of automotive science."-MotorTrend
Old May 31, 2001 | 01:53 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
It's really easy, all you need is a steering wheel puller tool, about $10 at Autozone.
after you remove stock wheel, you attach the grant adapter kit, put the Grant wheel on and screw the wheel to the adapter with the supplied allen screws.
Fairly simple install.
High Speed Run: 157mph
Best 1/4 mile run: 14.94@91.67mph
WS6 Trans Am.
View My Ride @ thirdgen.org
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
LittleFranks
Sep 17, 2015 12:22 PM
redmaroz
Aug 16, 2015 11:40 PM
