Goodmark fender question
Old Jan 31, 2013 | 12:59 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Quick question if anyone knows. On my 92 Camaro, the drivers side front fender and door have some damge on it from a side swipe before I got it. It might be able to be fixed, but i'm not a body man. I'm thinking of just getting a differant fender and door. I see that Summit Racing has the Goodmark fenders for $79.99 and to me that's not a bad price. My question is will that fender work with my 92 GFX or will I have to mod the new fender to work with the GFX? I did a search and did not find anything.
Thanks Ben.
Old Feb 1, 2013 | 02:17 AM
StripedZ28's Avatar
Car: 1985 Z28 Camaro
Engine: 390CI SBC Stroker
Axle/Gears: 4.10 (Ford 9")
Re: Goodmark fender question
It will work. They didnt change how the ground effects mounted to the fender.
Old Feb 1, 2013 | 10:41 AM
2007xl50's Avatar
Engine: LB9/3.1
So the new fender will have pervisions for the GFX then? Summit's website had very little info on the part and it's a order in part so it's not like I can go to the store and look at it first.
Old Feb 1, 2013 | 06:45 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
it has the provisions for the 91-92 gfx looking at goodmarks website
Old Feb 4, 2013 | 12:42 PM
2007xl50's Avatar
Engine: LB9/3.1
Thanks so much! I think I might just order one instead of trying to find a used one since the price is not bad.
Old Feb 6, 2013 | 12:40 PM
bobs's Avatar
Car: 87 Iroc
I just one a couple months ago. Ordered direct thru Goodmark due to there shipping charges being a whole lot less then anybody else. It is not flimsy at all and should just be minimal final fitting. Lines look pretty good during mock up. Waiting for spring to paint and final install. There are all the correct 91-92 ground effect mounting points.
Old Feb 6, 2013 | 01:01 PM
2007xl50's Avatar
Engine: LB9/3.1
Thanks for the info, I have located a used fender from a member on here, but have to find a way to get them.
MustangBeater20
Oct 29, 2022 09:20 PM
TEEZER TA
Aug 30, 2015 06:35 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
