Paint Touch-Up Help
Old Jun 14, 2001 | 09:44 PM
87CamaroChris's Avatar
Car: 1987 Camaro
Engine: 305 LG4 Carb. (no ECM)
Transmission: TH700-R4
Paint Touch-Up Help
I have quite a few spots on my car where a little bit of rust formed and the previous owner decided that it would be a good idea to glob white-out onto it. I don't have the money right now to get a new paint job, so I want to hide it as best I can. Any steps I should follow to actually do touch-ups and make them blend in??
1987 Camaro Sport Coupe
305ci 4bbl (LG4)
3.23 Gears
THM 700-R4 Automatic Transmission
All Stock
Old Jun 14, 2001 | 10:50 PM
Car: 1987 Camaro
BTW, I also want to find out what the closest match to the white paint that GM used on the 87 Camaros is (if someone could please tell me).
305ci 4bbl (LG4)
3.23 Gears
All Stock
Old Jun 15, 2001 | 03:02 AM
86ZRICHIE's Avatar
your best bet would be to get a pro quality paint and a HVLP gun obviously, assuming you don't have that, go to an auto-body shop and tell them you need a touch-up can mixed, they should be able to do it using the same quality paint.
EDIT:should read auto paint supply store
[This message has been edited by 86ZRICHIE (edited June 15, 2001).]
Old Jun 15, 2001 | 08:37 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
First thing, get rid of the rust!! If you only cover it it will just come back.
Old Jun 15, 2001 | 10:45 PM
Car: 1987 Camaro
I was just thinking about trying that touch-up tutorial in the tech section and I'm thinking about just carefully sanding the rust out (if I can). I was also wondering if anyone has tried following that little tutorial and if it looked good.
305ci 4bbl (LG4)
3.23 Gears
All Stock
Old Jun 17, 2001 | 02:02 AM
87RS402's Avatar
The best place to look for touch-up paint is the nail polish isle at your favorite store. Espescially if your looking for red. I've found gray, white, black, hugger orange and most others. Just make sure that you get enamel. You cna also mix the colors if you can find the exact shade you need.
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
