89 TA hatch lock removal w/pics
Old Mar 3, 2013 | 12:04 PM
whtltng89's Avatar
Car: 1989 TA
Engine: 5.0L
How in the h*** do you get the rear hatch lock out? Ive drilled the rivets out and managed to get the outer bezel off. Tried to insert the key but that didnt help. The key wont work in it anymore and even the door locks are acting up. So,since Im prepping it for paint,decided to replace them all. Anyone got an idea?
Attached Thumbnails 89 TA hatch lock removal w/pics-dscn0110.jpg   89 TA hatch lock removal w/pics-dscn0108.jpg
Old Mar 3, 2013 | 01:08 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 89 TA hatch lock removal
I just drilled out the two rivets
Old Mar 3, 2013 | 06:54 PM
whtltng89's Avatar
Car: 1989 TA
Engine: 5.0L
Like I said,I drilled the rivets out. And the ONLY way its going to come out is to take it farther apart. On mine the white plastic is mtd on the outside.
Old Mar 6, 2013 | 06:03 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Need to pull the end of the cable off of the back of it before it's going to come out... Or it will never fit through the hole... It just pulls off (or pushes off with the help of a screwdriver).
Old Mar 7, 2013 | 05:35 PM
Steve86TA's Avatar
Car: To many to list
Re: 89 TA hatch lock removal w/pics
just pry the white plastic piece off the lock cylinder. I will come off
Old Mar 13, 2013 | 06:40 AM
whtltng89's Avatar
Car: 1989 TA
Engine: 5.0L
Ive tried and tried to get this apart to no avail. Will someone post a pic of one thats already apart? I dont really want to ruin the one I have.
Old Mar 13, 2013 | 11:24 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Try putting bolts back into the holes that the rivets came out of before you try to pry off the lock cable again... It helps to have some support on the lock before you try to pry the cable off. Then, once you get the cable off, take the bolts and the lock out.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
3rdgenparts
Aug 8, 2015 07:09 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
