tire sizes?
Old Jul 1, 2001 | 12:59 AM
92 z28's Avatar
tire sizes?
on my tire it says 235/55/16. now i know the 16 stands for the rim size, but what exactly does the 235, and the 55 stand for? i have the 92 z rims, would i be able to put 245/50/16 tires on the rimes?
dozer80464@aol.com
Old Jul 1, 2001 | 02:41 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
the tread with is 235mm wide. the height of the tire from the rim to the tread is 55% of 235mm and the tire fits a 16in wheel. whether or not 245/50/16 will fit depends how wide your rim is, but i doubt you will have a problem fitting 245's if you already have 235's on now. just remember that with the 235/55/16's, the tire diameter is 26.177" while 245/50/16's would be 25.646" the difference will throw off your speedo
Old Jul 1, 2001 | 08:34 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
245/50-16 would probably make your speedo correct since it's the factory size for 16x8 wheels
The mind is like a parachute, it only works when its open
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
