keyless entry Q?
Old Jun 27, 2001 | 11:47 PM
92 z28's Avatar
keyless entry Q?
hey, i have a 92 z, i purchased the car not long ago, when ever i used to lock or unlock the doors with my keyless entry the almost all the lights in the car would flash, now for some reason no lights flash when i lock or unlock the door, it is a viper 300 alarm, does anyone know what may cause this, and or how to fix it?
dozer80464@aol.com
Old Jul 1, 2001 | 01:14 PM
BigL350's Avatar
Check the parking light fuse on the alarm. It's on the white wire about four inches away from the alarm brain. It should be taped up, and if it isn't that's probably why it blew. If it's not blown, check where the white wire connects to the parking light wire of the car. It should be a brown or a white wire. I good test light really helps out. make sure the parking light relay inside the alarm brain is clicking. If it isn't you need to replace the brain, or there might be a programming step for parking light output, but I doubt it on that alarm
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
