Rear spoiler question
Car: 1989 Iroc Z L98
I have an 82 berlinetta i bought, and i have discovered the hatch has been updated. it has the 3rd brake light on the spoiler. anyways, the spoiler was broken, so i got another with the 3rd brake light, and this one sticks out about a 1/2 inch past the hatch, and doesnt line up with the driver and passenger sides of the spoiler (little triangle things). anyone know why this one doesnt fit? thanks
Car: '89 GTA
Engine: ZZ6TPI
The rear hatches on both my 86' and my 89' did not line up. The hatch stuck out about 1/2" past the quarter panels on both sides. You might be able to adjust the hinges by loosening the bolts and moving the hatch. I never tried it, never bothered me enough.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Magnaflow cat-back,
K&N open element,
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There is a tech article on this for properly aligning the rear deck.
The glass hinges are not designed to be adjusted (unless I have a prototype '87 & '84). If you feel the need to check anyways, use a sealant to reseal the hinges to the body to avoid leaks.
*edit,, I'll even give you the link
https://www.thirdgen.org/newdesign/t...tchalign.shtml
The mind is like a parachute, it only works when its open
[This message has been edited by deadbird (edited July 16, 2001).]
colton_carlson
Mar 8, 2019 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
