Problem with split rear seat
Old Jul 19, 2001 | 10:03 PM
Hugger3's Avatar
Anyone else experience this alignment problem, know what causes it, or how to fix it?
Old Jul 19, 2001 | 10:46 PM
maksik7's Avatar
Try taking both the backs off. I bet that the PS half came off the metal shaft connecting the 2 of em at the bottom and it should be a pretty easy job, jsut take the tops off and slide them back onto the metal shaft.
Old Jul 19, 2001 | 11:50 PM
pookey's Avatar
If you put a 1 inch lift the left side of the car it will make the seats even. Just kidding. Take the seat out and keep the mounting brackets. They are probably broke. Might want to consider a solid rear seat.
88 White Formula 305 TBI With A New CD Stereo and Abolutly Nothing Else Done To It!
Old Jul 20, 2001 | 12:07 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The problem is the left seat wasn't put onto the center hinge post properly. You can see from the picture that it is sticking out of the seat entirely at the bottom. You need to remove the bottom cushion, then you can get to the outer hinge nut holding the upper rear seat from below. Then lift it up and tip it out towards you. Then slip the center post into the hole in the bottom of the seat. Rotate the outer seat back back into place dropping the hinge bolt into the bracket and re-install the nut, then the lower cushion and your done. Good luck, Lon.
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
z28addict8490
Aug 7, 2015 08:48 PM
