Floor pan rust update
Old Apr 28, 2013 | 09:47 AM
nickyakker's Avatar
Car: 1982 Firebird T/A
So yesterday I started my floor pan rust repair. I started on the passenger side, I know im doing both driver and passenger side and installing new carpet so I just quickly took the seat out and cut the passenger carpet out up to the center console and covered the center console and driver side with a sheet.
From there I cut out the passenger side floor pan from about 5 inches from the front seat mount all the way to the firewall. I noticed that the floor pan is tack welded to the subframe, also the heat shield is screwed to the floorpan were I cut it out. this took me roughly 3.5 hours using 3" cutting wheels on my die grinder.
Once I measured my hole to fill I cut out my 18 gauge sheet metal. dry fit it, assessed where I would have to cut the sheet metal to achieve the dips and curves you need to assure you are still going to seat yourself on the sub frame and tack weld to it.
So far im about 3/4 the way finished installing the new pan, so far ive spent 10 hours including a couple hours for break. I would like to post pictures but Im unsure how to post them. If anybody would tell me how I would like to show you my progress
Old Apr 28, 2013 | 11:02 AM
nickyakker's Avatar
Re: Floor pan rust update
ok, figured it out
Attached Thumbnails Floor pan rust update-wp_000370.jpg   Floor pan rust update-wp_000371.jpg   Floor pan rust update-wp_000373.jpg
Old May 5, 2013 | 09:10 PM
BLACK92B4C's Avatar
Car: 92 B4C 1LE/2010 GT/2003 P71/2002 Z2
Engine: 5.7/4.6/4.6/5/7
Transmission: A4/A5/A4/A4
Axle/Gears: 3:23/3:73/3:23/3:73
Looks like good progress!
Old May 6, 2013 | 10:16 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
If you tube chassis it, then you can itstall flat floor pans.
aharvel50
Sep 21, 2015 07:31 PM
Lanz06
Sep 14, 2015 07:16 PM
machinist21
Sep 5, 2015 03:03 PM
mrdevontay
Sep 2, 2015 08:04 PM
