Pass. side power door lock will work sometimes then it won't ...
Old Aug 4, 2001 | 06:44 PM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
What do you think is wrong and how can I fix it??oh btw its an 86 IROCZ..
Drive it like you stole it
Old Aug 4, 2001 | 10:37 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
Does the driver's side door lock work? If so, then you probably just have to remove the passenger door panel and squirt some WD40 on the solenoid and the linkages. Do a search in this forum, there are a few articles dealing with it.
If your driver's side power lock doesn't work, then it's likely that the power door lock relay may have a loose connection (same problem in my '86 IROC). Remove the driver's side kickpanel; you'll see a little silver box screwed into the frame. Re-seat those connectors. You may want to put a few drops of WD40 on the connectors before you do that, though... WD40 is good stuff
Old Aug 5, 2001 | 09:25 AM
IROCME's Avatar
Car: 1986 IROCZ
My drivers side does work,I will look at it today,thanks for the advice
Old Aug 5, 2001 | 10:26 AM
rudys119's Avatar
i have the same problem and was wonderin what to do, on the drivers side the door dosent wanna lock but it will unlock fine, on the passenger door it will lock but dosent like to unlock.....
87 GTA 350 TPI
Mods: K&N Air Filter, New rocker arms, Stage III chip.
Next Mods in line: Exhaust, headers
http://www.geocities.com/rudys120/transam.html
Kills:
87 Mustang 5.0,
89 Mustang 5.0 (modded)
?? Iroc
00-01? Jaguar driven buy 85 yr old guy
Too many ricers to count......
Old Aug 5, 2001 | 10:35 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Rudy, I would suggest checking the relay first. It's easier than taking off the door panel and lubricating the linkages. When I bought my '86 IROC, the doors would only unlock; they wouldn't lock. Reseating the relay connections fixed it. Read my previous post to IROCME for the location of the relay. Hope this helps.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
BrianI
Aug 9, 2015 11:52 AM
