Firebird headlights not working...need help
Old Aug 16, 2001 | 12:08 AM
MILT's Avatar
Okay, so my flip up headlights decided that they didn't want to flip DOWN anymore. Everything else works fine. The lights had been working fine, then I tried to turn them off and they wouldn't go down. What's the deal? Is there a fuse or relay I should check?
Danka,
MILT
Old Aug 16, 2001 | 12:50 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Did the headlight motors run when you turned off the headlights? If they did you probably have a stripped gear or broken drive bushings (if you have an '87-later model). If you have the earlier headlights with the wierd 3-wire setup its probably an electric problem and you should check all of the connections and make sure the right wires are grounded.
[This message has been edited by RedFirebird (edited August 15, 2001).]
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
rh76camaro
Aug 29, 2015 06:53 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
