Door Lock Keys
Old Aug 15, 2001 | 08:26 PM
Faught's Avatar
Door Lock Keys
Anyone know where I can get the codes for door loack keys. Recently purchased an 85 "bird" and through its life span its origonal door keys disappeared. Have been to local dealer and was told that they only go as far back as 90
Old Aug 15, 2001 | 10:27 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
PHS sells a package for 49.00 that includes a copy of the original invoice. My copy has the origianl key codes printed on the invoice. The other documentation in the package was awesome as well, so I would call it worth the money.
Chris G
91 TA WS6
See more of her here!
Old Aug 16, 2001 | 09:21 PM
david foraker's Avatar
if you need new door lock cylinders and keys, go to autozone. they can sell you two lock cylinders and two keys for under 15 bucks all you have to do is install them, which is a breeze. hope this helps
Old Aug 17, 2001 | 01:34 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have been to SOME salvage yards where they keep the keys on a string around the steering column. You can pop of a set from a junkyard, get the one from the hatch, install em in your car.
You can also remove one of them from the door and take it to a locksmith, they should be able to match a key for you.
On a similar note to give you an idea. When I bought one of my cars it did not have a the correct T-top on the driver side, it had no key hole. I went to a junk yard, found a broken T-top and took the metal bar & trim pieces. I took apart the lock and stuffed my key in it. I then filed the tumblers to fit my key.
The short of it is, there is alot you can do.
John
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
g.l.mos
Aug 22, 2015 12:02 AM
