Power window Alignment?
Old Jun 19, 2013 | 10:41 PM
86chevinit's Avatar
Car: 86 Camaro
Engine: V6
Hi guys,
I recently noticed an air leak on my drivers side once I get past 40, the leak seems to be coming from right around the triangle and the window it self feels a little loose against the weatherstripping in the same area.
My gut tells me if I could get the window up another half inch there would be enough pressure to seal off the leak.
My buddy also put it to me that it could be the motor itself starting to die.
Once I get the door panel off, is it safe to assume I can get the job done with a 8 and 10mm wrench? Should I just replace the motor too?
Thanks in advance!
Old Jun 20, 2013 | 10:03 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Power window Alignment?
The window triangle itself can be adjusted without adjusting the
window.
I had to adjust my triangles to stop wind noise.................
Old Jun 20, 2013 | 02:37 PM
86chevinit's Avatar
Car: 86 Camaro
Engine: V6
Thanks!
Ya I need to replace an exterior window sweep too so I will see what I can do with the triangle
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
