Carpet Color
Car: 1986 Firebird
Engine: not stock 2.8
Carpet Color
Ok, here's my dilemma. I just got my '86 Firebird, and she's in great shape. Only problem is, i'm not all that hot on the red interior. I was wondering what is a good dye to use to change the carpet from red, to black. The carpet's still in awesome shape and I'd hate to go thru the pain of removing it and swapping a black one on. Any suggestions?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Unfortunatly (at least what I've tried) there is no spray dye that works/holds up really well on the carpet.
The mind is like a parachute, it only works when its open
Car: 1986 Firebird
What about other types of dye, it doesn't need to spray on.... I'll work it in on my hands and knees if i have too! Suggestions?
Engine: TPI 305/ v6
I suppose you could use a cloth dye like you would on clothing, but I think that has to be rinsed afterwords, I've never dyed clothing personally so I can't say for sure. If that did work, the carpet would still have to come out (the work you're trying to avoid) to rinse it (if that's the case). Not awfully positive what the carpet is made from but, if it's a nylon type material, I don't know how well that would take to dye either, I know stains seem to hold thier ground pretty good though.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have only done this to black carpet in a black interior, so take it at face value. There were some white spots in my carpet where someone had put something and it ***** down the carpet to almost nothing. i took some black spraypaint (with the seats out) and sprayed those spots, I worked it in with a cheep hard brissel brush. like a 4" x 2" brush works fine.
Might not cover Red great, but if your going to trash the interior anyway why not try a spot. sounds like more work than I would be willing to go through. I would buy new carpet from JC whitney or Classic Industries beore I spent that much time.
John
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
John
5.1 TPI Automatic
83 Camaro (Parts)
83 T/A (parts)
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
Dragonsys
Sep 25, 2015 03:51 PM
