Struts to use w/ Fiberglass Hood?
Old Sep 8, 2001 | 05:18 PM
Cam350TBI's Avatar
The problem i am having is with the opening of my hood. Its fiberglass w/ the stock steel hood lift struts. When I open it i have to partly lift one side and then walk around to the other side and lift it up partly, then I have to walk around to the front and finish lifting the hood up. As you can see this is a pain in the @$$. The guy i bought the car from said I would need to get the struts that were on an '82-83 camaro that came w/ a fiberglass hood. Does anyone know what he was talking about? What do I need to do to fix this problem? Any help would be appreciated.
Old Sep 8, 2001 | 05:43 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I had a fiberglass hood on my Iroc until I swapped it back to a stock hood. I talked a friend out of throwing away his worn out struts. They worked perfectly for the lighter hood. Your problem could also be from improper alignment ot the hood and hinges.
Old Sep 8, 2001 | 07:25 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
Yes, he is right. Worn out struts are the best for lighter fiberglass hoods. I have the stock struts on my camaro still with my fiberglass cowl, and the struts would not hold up my stock camaro hood, but worked great for my lighter hood. Get old struts out of the junkyard (they sell for cheap) and try that.
-------1992 Z28------
**New Evolution Racing**
http://ourworld.cs.com/ryanflowe/myhomepage/auto.html
<A HREF="http://ourworld.cs.com/ryanflowe/myhomepage/favorite.html" TARGET=_blank>
http://ourworld.cs.com/ryanflowe/myhomepage/favorite.html</A>
Old Sep 9, 2001 | 09:36 PM
Metallicamaro's Avatar
When I went to Autozone to get hood struts I aked the guy at the counter what the part number was for my car and he asked me what kind of car, year, engine size and if I had a steel or fiberglass hood. So I guess that means that they must make them for a fiberglass hood. D
91 Z28, 350
Dynomax cat back, K&N filters and gutted airbox
Frozer!!!
Jan 19, 2024 04:55 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
blackandblue02
Sep 10, 2015 08:19 PM
SG91camaro
Sep 5, 2015 10:27 PM
