power window motor./
Old Sep 17, 2001 | 02:41 PM
jeremyd19's Avatar
is it hard to install?or should i just take it to the shop and pay there outrageous labor prices!
Old Sep 17, 2001 | 03:03 PM
91'firebrd's Avatar
It's hard to get the old one out. It's also very awkward trying to hold up the window as you slide wheels inside tracks that hold up the window. Window always seems to work against you, trying to go down. Read power windows 101 in tech articles.
Old Sep 17, 2001 | 08:16 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Is there a junkyard (one where you pull your own parts) near you? The reason I ask is you can try your hand at trying to remove one off an F-Body. As 91'firebrd stated, removing the motor is the hardest part. Here is the link to windows 101: https://www.thirdgen.org/newdesign/t...rwindows.shtml
Make sure you bring a drill to pop off the rivets. As far as parts goes, I would either buy a new or rebuilt motor. Do not get one from a junkyard. Ensure you test the replacement part prior to installing it into the car. Hope this helps.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
