86 automatic shifter removal
Old Sep 21, 2001 | 12:18 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I did a search, and I'm not quite clear on how to remove the shift **** on my 86 auto. It has the ball shifter.
Does the button just pull out? Is there a clip in the front of the shifter? A rather detailed instruction would be much appreciated.
Thanks.
Old Sep 21, 2001 | 12:27 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
NOT sure about camaros, but in my firebird, there is a little clip on the front side that holds it on. Take the smallest flat screwdriver you can find, and pull out the clip.
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Sep 21, 2001 | 12:38 PM
texasgt's Avatar
Car: 2003 HD 1500 4 door Chevy
Engine: 6.0
Transmission: 460LE
You pop the button out (carefully) and then you will see a c-clip(snap ring) at the bottom of the ****. There is a specific tool that you may need to locate (snap ring pliers) to remove the ****. The **** just lifts off.
Old Sep 24, 2001 | 02:20 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I changed mine with a very small screw driver. We then put the leather wrapped ball on and poped the c clip back on. Turn the button slightly and pull up. It set's in some grouves. Not hard to do and even easier to re install once you can see it. Here's a tip;Go to the junk yard and practice on some wreck. That's what I did so I wouldn't mess my car up.
86 Camaro Black SS Coupe, T Tops, ASCD Daytona Twin Turbo hood, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
'91 RS 5.0 TBI = Waiting to be modded, but has all of the toys inside.
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
