Door lock instalation
Old Sep 24, 2001 | 06:29 PM
miked's Avatar
I have a car that did not come with power doorlocks. I have purchased a pair of aftermarket doorlock actuators. I believe that the stock actuators mount in the bottom corner of the door. Could someone give me an idea of how the rod from the actuator mounts to the lock release. Thanks for any advice.
Old Sep 25, 2001 | 07:09 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
My aftermarket actuators came with little metal clips that hold the rod from the actuator onto the rod on the door lock rod. I mounted the actuators about 8 inches from the rear of the door and 6 inches down from the top if I remember right. There should be a nice big hole in the door sheetmetal there.
'91 RS 3.1
SSM SFC's
Energy Susp. Hyper-flex kit
GTA Sway bars
Clarion, Phoenix Gold, JL Audio, etc.
Pictures: http://albums.photopoint.com/j/Album...=13412261&f=0]
Quote: "If you can't beat them, arrange to have them beaten."
- George Carlin
Old Sep 25, 2001 | 08:58 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The most important thing is to find a spot where you can securely mount the actuator perfectly parallel with the rod. If you mount it on an angle, over time you'll burn out the actuator.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
