fuel cell question? rear hump
Car: 86 IROC-Z28 Camaro
Engine: 69 small block 355
Transmission: TCI Turbo 350
Axle/Gears: Ford 9 in 36 spline?Detroit locker
So I had I thought I was wondering if anyone has tryed to eliminate the rear hump over the gas tank and fab there own floorboard after you take out the tank. Possibly weld in tubs too?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: fuel cell question? rear hump
Not sure why you would do this? The fuel cell would be under the car where stock gas tank was, not inside the cabin. Maybe i am not following you here?
Nasty performance makes fabbed cells that will fit in stock location but they are pricey
I was thinking there's alot of room back there and it would be a smaller tank I could have swarn I seen a fuel cell inside a car b4. But main thing is to make room for batteries or a amp or anything for that matter it was just a thought to put in tubs and make more room.
colton_carlson
Mar 8, 2019 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
