Newbie to rust..need suggestions.
Old Sep 2, 2013 | 12:40 PM
Caleb_91RS's Avatar
Car: 91 Camaro RS.
Engine: 3.1L V6 :(
Being new to cars..and rust, what I found on my car has me worried it'll turn into a bigger problem.
There's about a quarter size spot of rust (surface rust?) on both rear 1/4 panels.
Also, both my rear and front ends are rusted.
The (excuse lack of knowledge) metal bar that runs between the gas tank and rear bumper is rusting.
I need suggestions on what to do to stop, remove, prevent etc. rust as much as possible. Any methods/procedures would be appreciated.
Attached Thumbnails Newbie to rust..need suggestions.-img_0875.jpg   Newbie to rust..need suggestions.-img_0876.jpg   Newbie to rust..need suggestions.-img_0877.jpg
Old Sep 2, 2013 | 07:28 PM
Kingsobieski's Avatar
Re: Newbie to rust..need suggestions.
It just depends on the amount.....It usually is worse than it looks.....Start by using a grinder to take it down to metal, then check to see if it's too thin to fix, at which point you need to replace the metal with a patch (welding,cutting,grinding) then smooth the patch out with body filler, then (sand,prime,sand,paint,clear). If you have zero experience it's better to find someone that does to help you with it or you may just end up with a big mess.
If it's not a visible area, you can sand it down until you hit metal, then brush prime the area and brush paint over it.
Amillionoh7
May 24, 2020 08:01 AM
rubblerubble
Mar 13, 2016 06:57 PM
gord327
Oct 3, 2015 01:25 PM
BWilcox
Sep 20, 2015 12:19 PM
R3500
Aug 24, 2015 09:05 AM
