door panel
Old Oct 19, 2001 | 01:57 PM
CaMaRo_Berlinetta's Avatar
door panel
does 87 trans am door panel fit on 86 camaro doors ?
Old Oct 19, 2001 | 03:15 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Should, unless youre talking about the formed door panel. Then all you need is the metal bracket for the armrest that is riveted to the door & the interior door handle (opener) is different. Everything else appears to be the same.
The cabled remote mirror mounts differently too.
John
G O D BLESS AMERICA
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro
83 T/A
http://www.3rdgenformula.com
Old Oct 19, 2001 | 05:39 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I have some Formed doorpanels off of a 89 GTA in my car. You need the brackets for the door panel. the inside door handle opener maybe different but mine worked. I had manual driverside mirror and I just secured it to the inside of my door so it wont rattle around. other than that is should work if yours is electric you could extend the wires to your console bellow the window switches or an easier way i think is to have it on the carpet part of the console by your legs.
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
